changing brake pads
changing brake pads
We're getting new brake pads and the quotes we're getting from shops/dealers all include doing the rotors. For those of you who switch out brake pads often, do you do this without doing anything to your rotors?
Some pad manufacturers recommend the residue of the previous pad be cleaned off which can be done with sandpaper. The specs on the S2000 rotors do not allow much material to be removed so I would not turn them unless there is a surface variation (feels like a warp) that needs to be cleaned up.
pads, I've changed out a few times. Sandpaper works fine on the rotors, anything between 150 and 220 grit sandpaper will be suffice. But if you are upgrading from OEM pads, I don't really feel its too necessary.
It is customary, although often uneccessary, for a shop to turn the rotors when replacing pads.
You usually want to turn the rotors when they get warped, uneven, or gouged. I went through a set of stock pads, a set of Porterfield R4S's, and a set of Panther Pluses, then turned the rotors when i added my last set of Panther Pluses.
Sidenote: The Panthers use rivets to bond the friction material to the backing plate, and will score your rotors if you let them get to low. Long before a bonded pad would cause damage. The heaviest wear is on the inside front pad, which is also the most difficult to inspect. So if you use Panther Plus pads (which are great pads), make sure to inspect them frequently!
On the plus side, pulling the rotors was a breeze, even after many track day heat cycles, and the local shop turned them for about $8 each with an hour turn-around.
Originally posted by pfb
...On the plus side, pulling the rotors was a breeze...
if you do decide to drill out the bolts, replacements are only 43 cents a pice (4 required).
Originally posted by Schatten
only if you have an impact gun, or else
I recommend a small amount of Never-Seize on the threads and on the counter sink part of the screw before reinstalling on hub . This will make removal very easy in the future . You will notice that the threads for these screws go a the way through the hub this make rust a problem in the salt belt .
brad
brad
TheSoundMan21
03-01-2010 02:11 PM
monkeymaker
07-21-2002 06:23 AM
