CEL and bad catalytic converter...okay to track?
Old 06-29-2005, 07:46 PM
rlaifatt's Avatar
Default CEL and bad catalytic converter...okay to track?
My CEL has been on since the last track day, code reader says secondary O2 sensor, and I can hear some rattling in the cat when idling. I was assuming that it won't affect the engine since the primary O2 sensor should be okay (so I kept running it without incident at last track day at Fontana), but is there any risk if the cat physically deteriorates further? E.g., coul exhaust flow be impaired causing damage? Bottom line is, is it safe (to the engine) to still track the car for 2 days this weekend?
Old 06-29-2005, 08:03 PM
mikegarrison's Avatar
I would think the biggest risk is that the cat could plug up. This would probably not "hurt" the engine, but you would experience a decrease in power until you replaced the cat.
Old 06-29-2005, 08:04 PM
Slows2k's Avatar
I've seen convertors that have caused some serious performance issues when they become clogged. If the catalyst bed breaks up it can restrict the exhaust. If the exhaust is really well blocked, the exhaust gas will back up to the engine and super heat eveything. Valves, valves seats, cylinder walls/rings can all be cooked. You can make the call on safety,but I wouldn't track the car.
A cheap fix would be a test pipe and 02 simulator for "track use"
Old 06-29-2005, 08:08 PM
rlaifatt's Avatar
Uh oh, this is not sounding good.
Anyone with a spare converter that you could bring to Willow Springs this weekend?
Old 06-29-2005, 08:37 PM
Prolene's Avatar
I'll have Kyle haul ours out for you to use, if you want.
Old 06-29-2005, 08:53 PM
rlaifatt's Avatar
Thanks Al! I would appreciate that. I am assuming it won't be too difficult to do at the track with the car on jackstands.
I expect I would be able to get it replaced at the dealer under warranty, but don't have time before the weekend.
BTW, what's your excuse for not coming?
Old 06-29-2005, 11:06 PM
Prolene's Avatar
'Tis my weekend to give surgical coverage. I'll let Kyle know.
Old 10-27-2008, 08:07 AM
tinkfist's Avatar
Bump. My CEL went on at the track, mid-turn, a couple weeks ago and this was my code as well. I ran the rest of the weekend with no problems. I am wondering though if the cat or the oxygen sensor has gone bad. Richard, what did you find out? Anyone else having cat/O2 issues from tracking?
Car has 62k and 20+ track days on it.
Old 10-27-2008, 10:49 AM
CKit's Avatar
I've had a cat go bad with the same rattling and 2' O2 code.
I wouldn't be surprised if: you toasted the cat, causing pieces of the honeycomb to dislodge... shearing the head off the O2 sensor.
Does the cat rattle? Bring WD-40 to help with the bolts. Spare cats are abundant on the forum (or just bring a test pipe for track days).
It's easy to take the O2 sensor out (standard spark plug socket IIRC) to check. Aftermarket replacements are available <$100 at your local Advance Auto Parts.
Old 10-27-2008, 11:17 AM
davepk's Avatar
A word of caution.
Do not put a replacement O2 sensor into the cat that a bad(broken) O2 sensor was removed from.
You'll end up with two broken O2 sensors if you do.
Quick Reply: CEL and bad catalytic converter...okay to track?
