carbotech pre-broken in?
orderred some new front xp10 pads and rotors from carbotech and they said would I like them all ready bedded in
I thought I'd try it for $20 anyone know about this - do you have to buy rotors with pads for it to work?
Seems like you would have to do pads and rotors, since part of the process is conforming the surface of the pads to the profile of the rotors, and part is transferring material from the pad to the surface of the rotor. The last bit, that wouldn't require rotors to go with the pads, is baking & pressing out volatile chemicals from the pad material.
There is another thread covering this but Bedding in the rotors is very easy to do and can be done at the track without all the ramping stops and cool down process. It was also noted that the pads have more material when they are pre bedded than if you bedded them yourself.
Originally Posted by metros,Oct 10 2009, 06:36 PM
I was just looking to order some CT pads today. Do you have to call CT to place an order directly from them? I didn't see any way to add to a cart or order online.
Just call them directly if you are going to order (877-899-5024). Ask to speak to Mike, Jr. and tell him Wynn from Nashville sent you. He should hook you up with a discount on the pads
XP8's should be good for the street. I still run my 10/8's on the street and they work really well. Better than stock as long as you don't mind the noise My rear XP8's don't really make any noise though.
They will eat the rotors on the street and they will dust like crazy! I loved my ax6 as street pads but ultimately I went to the bobcats to reduce the dust so it wouldn't act like cement on my wheels.
