Can we run a 275 A6 Hoosier on a 7.5" rim?
Old 07-23-2008, 04:41 PM
  #21
PilotSH's Avatar
[QUOTE=Orthonormal,Jul 23 2008, 09:43 AM] wsj3200 has an AP1.
Old 07-23-2008, 06:33 PM
  #22
Orthonormal's Avatar
Darrin could take CS in the 2007 Miata this year -- I was convinced over the past two weekends that it is a very good car for CS. I definitely want to drive one sometime and see what kind of damage I can do to the local PAX...
Old 07-23-2008, 08:18 PM
  #23
sirbunz's Avatar
Thought I would question/clarify a couple of things ... Ive not heard of anyone running a 275/295 setup on an ap2. Also, the 295 fits the solstice better than the 285 on the 8" rim according to many Solstice owners at the National Tours. Something about the way the tire beads off the rim. About the delayed response by putting a bigger tire on a small rim ... from my experience, the 275s on the 7" front rim of the CR provides much more initial bite than the 245s ever did while providing over an inch more of contact patch. Just my .02, best of luck with your setup!
-Marc
Old 07-24-2008, 05:30 AM
  #24
wsj3200's Avatar
Originally Posted by Zachreligious,Jul 23 2008, 06:32 AM
AP1 or AP2?
2003 AP1
Old 07-24-2008, 06:44 AM
  #25
Forcednduckshn's Avatar
-Marc
thanks!!!
Old 07-24-2008, 05:46 PM
  #26
wsj3200's Avatar
Originally Posted by Orthonormal,Jul 23 2008, 07:43 AM
In the AP2 on 275s, I was all over the limiter on both days, especially Sunday. Interesting that George and Joey stuck with the 245s on Sunday, but there's no denying that Joey was very quick on Sunday.
On Saturday, we hit the limiter in the first section after the start even after changing to the 275's. On Sunday, I was convinced the 275's was the tire to have. Joey wanted the 245's due to the fresher rubber. Our initial plan was Joey would take his first two runs on the 245's and I one run, then we were going to switch to the 275's for my final two and his final. But surprisingly, through the 3 runs, we never hit the limiter. So we stuck with the 245's. It wasn't until my final run that I hit the limiter approaching the Chicago box. But Reijo smoked both of us on 275's. I guess we need to pedal faster next time.
Old 07-24-2008, 07:36 PM
  #27
bigboost17's Avatar
-Marc
Marc- I haven't heard of a 275F/295R, but there was a guy from S.C. @ the Devens Tour ( Yellow AP2 ) that was running 245F/ 295R. I can't speak for him though as to how it handled or drove.
Also I was curious about the 275F that you have been running. I have the A Stock Valved Konis, and I am curious if I could get away with the 275 on the fronts . I am not sure of the 04 OEM front spring rates compared to the 08 CR front spring rates.
Thanks- Glenn
Old 07-24-2008, 07:39 PM
  #28
Good stuff man! Please, keep me and/or this thread updated as you go through the season and get real test results comparing the 245 Rear to the 275 Rear. My thought is the 275 is going to be quicker over the majority of courses. I did the quick math and overall diameter change is .9", good for about a 3.5% increase in total D. I'm not sure what that exactly means in terms of gearing, but my guess is it's not as signficant as people make it out to be, and in some courses may turn out to be a gearing advantage by staying in gear longer/not tapping over the rev limiter. So good luck with the S the rest of the reason! I'm on a bit more of a budget, so it's 245/275 combo for me for the rest of the year. I'm having Bill Gendron himself do my alignment (I have the pleasure of working 30 mins from his shop.) So it will be stock shocks, Gendron Bar, and 245/275 A6's tearing up New England A stock
Old 07-24-2008, 07:40 PM
  #29
Thanks- Glenn
Glenn, you running the prosolo this weekend? If not, wanna make a trip down to hartford and run it with me?
Cough cough co driver cough cough
Old 07-24-2008, 08:21 PM
  #30
bigboost17's Avatar
No I am not going to the Pro in Seneca, I am actually @ Devens this Sunday w/ the BMW club. Then it's 2 weeks off. Are you going to hte next 2 SCCA evenst in August? The 23rd is the RAL event @NHIS, this is fun, I won the novice challenge last year, now I'm gunning for the Jeff Gordon trophy this year. Then there is a points event on the 24th. It is a good time, and it is for a good cause. Plus its your type of typical CT course ..... it's the size of a postage stamp
Quick Reply: Can we run a 275 A6 Hoosier on a 7.5" rim?
