Camber & Tire pressure track set up.
Old 08-18-2005 | 04:49 AM
Tel1sps's Avatar
Default Camber & Tire pressure track set up.
I have been doing mostly autox this season and need some advice for track setup. I currently have -1.0 f and -2.0 r camber, with a comptech front swaybar, stock springs and toyo ra-1's on spoon wheels.
Is this camber good for the track? and what tire pressures would work best?
btw... I was planning to adjust the front camber to -1.5 after the last autox I noticed too much understeer with the Kumho's.
Old 08-18-2005 | 06:54 AM
Voodoo_S2K's Avatar
For the track, you will want significantly more camber for RA-1's. I've been told in the neighborhood of -4 degrees is optimal. I personally run -2 in the front and -2.5 in the rear since this is also my daily driver.
Old 08-18-2005 | 07:38 AM
WVtwisties's Avatar
does this give you terrible inner tire wear? on the street that is
Old 08-18-2005 | 08:40 AM
payneinthe's Avatar
I've never really noticed excessive inner tire wear with those settings, but it depends on tires and driving style. Btw, -2 is pretty much all you'll ever get outta the fronts without changing a-arms or ball joints.
Old 08-18-2005 | 09:00 AM
WVtwisties's Avatar
-4 is pretty extreme--no way for a car that ever sees the road
Old 08-18-2005 | 09:07 AM
Tel1sps's Avatar
What tire pressures do you run?
Old 08-18-2005 | 10:11 AM
Voodoo_S2K's Avatar
Its really depends on your toe settings. I'm getting some inside wearing on my front tires, but my front alignment is off. My rear tires are showing just a little bit of inner wear.
Old 08-18-2005 | 10:30 AM
Ludedude's Avatar
Administrator
Wear is more about toe than camber
Old 08-18-2005 | 10:33 AM
WVtwisties's Avatar
2 questions:
Do you want your alignment to be off??????
I have some idea but, how is tweaking the toe advantageous?
Old 08-18-2005 | 10:34 AM
pantyraider's Avatar
You'll wear it evenly as long as you use all 4 degrees
