CAMBER SETTINGS FOR TRACK - more in front or rear
Old 02-16-2009, 09:44 PM
Former Sponsor
949Racing's Avatar
A RWD car with IRS and good suspension geometry will almost without exception end up with more front than rear camber when properly tuned. So expect to end up that way after experimenting.
There is no "right" answer or "perfect" alignment for every condition though. Just compromises. When it's dialed well the compromises are very small and you get the end result you want.
You need a lap timer, fast and consistent driver, pyrometer. If you have alignment tools you can bring to the track, that's a bonus but you can learn a lot without changing alignment at the track.
Old 02-19-2009, 04:54 PM
racecar fun's Avatar
what's IRS? I...Racing suspension?
Old 02-19-2009, 04:55 PM
mikegarrison's Avatar
independent rear suspension
Old 02-19-2009, 08:09 PM
Administrator
krazik's Avatar
IRS is a crappy suspension that doesn't work well and takes way more than it gives
Old 02-19-2009, 08:20 PM
Billj747's Avatar
Originally Posted by ZDan,Feb 14 2009, 07:27 AM
S2k setups are usually more rear camber, but in many cases that's due to more rear camber being available, and also to the early S2k's rear roll stiffness bias. RWD production cars almost always run more rear camber for a safer more understeering handling demeanor, but more front camber is the norm for decent power/weight rwd track cars.
What's best on your particular car depends on the overall setup. Personally, I'd go for more front camber (~3 front, ~2.5 rear) and stiffer front vs. rear roll stiffness to balance.
As for pyrometer testing, be aware that even temps across the tread is not necessarily the ideal. The stopwatch is the ultimate measure of what's really optimal. Faster setups will often run hotter temps at the inside of the tread. This is partially because at higher speed straightaways, you're heating the inside tread more than you'll heat the outside during cornering.
+1
Normally a 20*F spread (with the inside being hotter and the middle of the tire in between outside and inside temps) is preferred.
Old 02-21-2009, 08:11 PM
krnmike's Avatar
interesting
Old 02-26-2009, 11:35 AM
THE_DIESEL's Avatar
-3.40 min front and -3 rear : what you say ?
Old 02-26-2009, 12:02 PM
Squirtle's Avatar
i say you have -3.4 front and -3 rear
Old 02-26-2009, 12:18 PM
THE_DIESEL's Avatar
Its good or not ?:-)
Old 02-26-2009, 12:21 PM
It's your car. You tell us.
Too many other variables between cars and drivers and tracks and tires.... What is good for me may not be good for you. What is good for you may not be good for me.
zeroptzero
03-27-2016 07:15 PM
ES2K
04-14-2015 08:41 AM
sillyboybmxer
05-23-2011 06:23 AM
r8byb
03-17-2009 11:00 AM
solomon
01-17-2006 11:02 AM
Quick Reply: CAMBER SETTINGS FOR TRACK - more in front or rear
