Camber Question
#21
Thanks guys. I'll check out those curves when I get back to the hotel, I'm still working and they have websense to block the photo sharing sites.
Man, it sounds like the S2 is the way to go but I can't find them for love or money.
#22
Originally Posted by twohoos,Jan 18 2011, 08:56 PM
Interesting curves, thanks! These were measured by moving the suspension through its arcs? What was the caster setting? I guess the stock adjusters weren't maxed out?
Also, it seems the S2 only added a bit over 2 degrees? Or were the adjusters changed to different settings?
The rear camber eccentric was set to produce about 2.1 degrees of negative camber at stock ride height.
The front caster was about 5.6 degrees the last time I measure it, which hints that my bushings are worn/tearing.
#23
^Were the dampers installed for these measurements? (Would it matter?)
Evasive had them in stock a couple months ago...
#24
#25
Yep, already tried N1 and evasive and one other board sponsor - all are out of stock and no idea when they'll come in next (although N1 thinks it'll at least be in the next couple months - everyone else had no idea).
But, I found them at Speed Alliance so I just got them ordered
#26
#27
Has anyone looked into the specifics on the Hard Race lower adjustable ball joints? (much less than the J printed on it)
I have the Science of speed adjustable upper control arms with -3.5 lowered and maxed out.
I think I want to go back to stock uppers and to the lower adj. ball joints.
