Brembo GT brakes
Brembo GT brakes
I can't find any info to say whether these fit under OEM MY04 17" alloy wheels?
They do say they come with fitting kit / spacers so I presume they will.
If not, are there any other BBK'swhich will fit? (not including Wilwoods)
Help appreciated.
Help appreciated.
The Brembo GTs do not fit w/o spacers under the OEM wheel. The only one that has a chance are the Rotora Minis.
But as most will tell you, upgrading the OEM brakes to SS lines, upgrading the fluid and pads, are more than sufficient for the track.
I don't believe the kit comes with spacers.
With spacers you really should run extended lugs to be safe. Also, I haven't heard of any issues personally but some say running spacers is not safe (although VW does it).
bc02
36
02-17-2007 07:37 PM
