Brembo BBK for the track
Hey I have a 07 with a Brembo BBK on the front and and am trying to see what brake pads people have been using all around that have a BBK on the car. It doesnt feel too un-balanced but I want to buy braided lines and new pads for the rear to even out my braking and to keep the front from doing all the work...
Anyone with experience with a BBK on a s2000 and pad choices?????? The car stops great... just want it to be neutral and not over working the fronts
Anyone with experience on this please chime in thanks
Former Sponsor
Your rear brakes don't do too much work. With a BBK, I wouldn't worry about overtaxing the front brakes as much as I would be overtaxing the front tires with too much front brake. A well designed BBK will take the brake proportioning into account when it is developed.
Ya i figured this out when i went with a 6 piston Wilwood BBK on my RSX lol... what brake pads would you recommend??? I know the backs dont do much work and im not worried about heat or anything... just Balance front to rear
speaking of bad proportioning... I have the stoptech kit on the front, stock rears. Past few track events, I've been running rear Autozone specials (duralast golds)... yes, the car is a bit sketch under hard braking, but it's manageable... I've managed to burn thru 2 sets of rear pads in about 5 track days... and since Autozone has lifetime warranties, I just returned the pads, got them replaced under warranty, walked out smiling.
Although the $190 XP10s would be nice to run with again, I can't really say they improved the braking significantly to warrant the extra cost.
Now if I was competing for money, different story.
OP- Are you asking about pads for street or track?
It will be for street use with some track days.. So even with the etra bite up front you still prefer the same pads front and rear?
I run PFC 08 in Stoptech Bbk front and PFC 97 in stock rears. Stopping power is phenomenal and wear rate is low. The only time I had issues with balance under breaking is when I had a poor alignment (rear toe was off)
Former Sponsor
Much of your braking force comes from the front brakes. They rears do do work, but not nearly as much as the fronts.
