Brake rotors upgrade choices
Well... Instead of going onto track today I'm writing this topic.
Needless to say, I cracked a rotor yesterday on track...
I'm looking for opinions on what brake rotors (front) should I be getting as an replacement/upgrade?
I'm not looking to buy a BBK, just needed a OEM replacement that may be more suitable for track usage and can last a little longer... Maybe an upgrade from my current settings..
My current brake settings :
OEM rotors
OEM caliper
Hawk HP+
Stoptech SS brake lines
Motul RBF600
What do you guys think??
Thanks.
Von
OEM rotors
OEM caliper
Hawk HP+
Motul RBF600
Thanks.
Von
Dont waste your money, fancy expensive OEM replacements dont last significantly longer than the cheap-o rotors. Autozones come with warranty that they will honor as long as the manager doesnt here you spouting off about race track this and that. Look for micro cracks that signal the end is a few sessions away. Always take spare front rotors to the track. Always roll the car to cool the rotors evenly after youve parked. If you have problems with HP+ just wait till you go full blown RComp. DIY brake ducts make the rotors last one extra weekend if you use the factory dust shields. One more weekend if you buy a proper fitting brake duct kit. Also the brake temps tend to go up when the pads are almost dead so be extra careful to cool the brakes good then. OEM calipers/rotors are just fine for track duty even if your experienced and fast so long as you dont mind spending the a few lunch breaks a year swapping rotors.
The only OEM size rotor that most likely won't crack are much more expensive 2-piece rotors like those from Girodisc. And don't just assume you will crack rotors. Pad choice and driving style and how you cool down the car after a session will make a massive difference.
Yeah I'm thinking about DIY brake duct this off-season.
Thanks! Looks like Centric/NAPA are the ones i'm going to purchase.
1. Brake ducts
2. Giro disc 2 piece.
This combo lasts me about a year of tracking (10 + weekends) with fairly aggressive pads (cobalt xr2). This includes time trial and wheel to wheel racing
