Brake Ducts (Almost) Finished
Old 01-02-2013 | 07:59 AM
  #51
robrob's Avatar
Originally Posted by Croc
i see.
what other options do i have given the fact that my car have and air pump and AEM v2 intake?
I recommend 2 1/2 inch ducting to the front bumper. You'll have to squeeze the ducting around the air pump but it still works fine.
Old 09-16-2013 | 12:09 PM
  #52
tekstyle's Avatar
i have been thinking. i was planning on putting 2.5" ducts and have placed a 2.5" inlet on the dust shield of my AP2. since I have a bunch of 2" ducts lying around. i just came to realize that i can probably squeeze 2 lines of 2" from the bumper ( the holes are long vertically but narrow horizontally) to about where the shocks are. then, place a dual 2" to 2.5" collector with a 90 degree of exit so the 2.5" duct is a straight shot to the rotors. this will introduce less fatigue on the ducts since the bends are handled by the collector and also prevent rubbing with 255 tires since stacking 2 2" ducts on top of each other is narrower than just 1 2.5". in terms of air pressure, a larger surface area inlet at the bumper reducing to a 2.5" outlet at the rotor will result in higher pressure than if the hose was just 1 constant diameter the whole way through.
what do you guys think?
S2000_916
04-15-2019 09:43 PM
S2Bray
04-07-2019 08:33 AM
S2Bray
04-05-2019 10:40 AM
tunerjetta29
02-08-2006 11:40 PM
S2kRob
04-17-2003 02:54 PM
Quick Reply: Brake Ducts (Almost) Finished
