AST 4100 Dampers
#101
The Eibach stuff can be found here: http://eibach.com/eibach/img/ers-catalog-2004.pdf
Also, you are forgetting about the motion ratio (.67 rear I believe). So with 750lb corner weight, there would be ~1100lbs on the spring.
#102
Thats a better catalogue than the one I found on their main site. nice find. Saved for later use.
yeah, I botched that one up. At work, tried to make a post in between tasks. yeah, I run 650s rear and they compress around 1.4"
#103
#105
Are these new ones a full threaded body?
When I had my 4100s the threads didn't go all the way down the body and with 600lb rear springs and helpers even with the perch as low as it would go the rear was around 12.75-13" ride height. It could not go any lower. I think some of the hyperco real low stack height helpers would fix the problem but I'm just curious now.
#106
Former Sponsor
#107
#110
Originally Posted by ndogg' timestamp='1354069826' post='22175829
What spring lengths are going to ship with these?
I know you said 6" front and 5.5" rear at one point but that seems kinda short in the rear. Potentially run out of spring travel...
This all assumes they are similar in dimension to the previous 4100/5100.
On a semi-related note: The first set of 4100's sold stateside back in 2008 just won double National Championships with NASA in the Honda Challenge H1 and Time Trial B class. They are on 6"x700/5.5"x650 springs respectively with AST spherical top hats. Four seasons of HARD racing on those shocks and they are still turning record laps!
-Aaron
