Anyone have instructions for WASP splitter
Last year I purchased a used Wasp splitter from someone local, it didn't come with the hardware to install. I contacted Bryan and after several tries was able to order new hardware, and I asked him to include the install instructions. I did receive the hardware, but never received the instructions. I have tried several times to contact him to get these, but have not had a response. Does anyone have a copy of the instructions they could send me? Thanks!
Kenny_Stang (02-21-2017)
I had to figure it out as well but this is pretty spot on. There is 3 alignment holes in the very back that you can use to bolt in at first then once those are secured use something to support the front. Line up the brackets to where you want and mark. Drill through the marked holes and this is where the hardware will go through with the brackets. The brackets do allow some margin for error which is nice. Remember there will most likely be a couple times you will take it off and put it back on to make sure everything is where you want it
Kenny, There are a number of threads on the install, plus you have solid resources in DFW (Todd and John)
Here is one with great pictures
https://www.s2ki.com/forums/s2000-ra...1028921/page2/
Thanks for the advice guys, my question is mostly around the way the support rods attach to the car. Do they attach to the brackets, or do they attach to the bumper support? Do the fender liners have to be trimmed or completely removed? I'm sure I can figure some of this out while I'm working on it, but was hoping to review the install to make sure I have all the necessary parts and tools (since I pieced it together).
FF2Skip
03-28-2004 07:16 PM
