Any affordable control arm bushings?
Old 09-17-2010 | 11:13 PM
  #31
ETKMS's Avatar
[QUOTE=vjarnot,Sep 15 2010, 03:48 AM] Sounds like a good option.
Old 09-17-2010 | 11:29 PM
  #32
jyeung528's Avatar
how long on average do oem bushings last before they get worn/damaged?
Old 09-17-2010 | 11:38 PM
  #33
ETKMS's Avatar
It really depends a lot on where the car is, and maybe what its used for. I can say, my car was always in Florida, and had 140k miles on them, and their was not one stock bushing on their that was not cracked or ripped in a way. So I would say after 100k miles if you are a track guy they should be replaced. If you only drive on the street, it is possibe they can last forever i guess in a way.
Old 09-18-2010 | 07:47 AM
  #34
vjarnot's Avatar
Originally Posted by ETKMS,Sep 18 2010, 01:13 AM
Yes, I did all of it myself. I had the car on jack stands for a little over 2 weeks. Mostly because i could not get a bolt out of front LCA so I cut it, and the compliance bushings were in bad shape so i ordered new front LCAs from Honda (huge rip off), but the bolt i cut was on backorder and took the longest to get in.
Over all the job is not that bad, mostly time consuming. Taking the control arms out was the easy part, same with putting them in. I did not use a press or anything. I just used a hammer, a drill (lots of broken drill bits) a torch, chisel, flat head screwdrivers, recipricating saw, sledge hammer, and a TON of elbow grease! LOL. I also wound up having to change my rear lower control arm ball joints since the threads were stripped. Just prepare to do the job and give your self a week to do it if all goes smooth. Hopefully nothing will break or need to be cut for you to need to order new parts. Also, all my powerflex bushings were way under $700.
Thanks for the very informative post. Any chance you could PM me where you got your powerflex set? I'm pretty certain that this is the direction I'm going to go, but I'll be getting a harbor freight press to do it...
Old 09-19-2010 | 12:07 AM
  #35
ETKMS's Avatar
Having a press is not a bad idea at all. I sent you a PM.
Old 09-20-2010 | 03:37 PM
  #36
scareyourpassenger's Avatar
Originally Posted by viets2000,Mar 16 2010, 02:44 PM
How much are they and how the heck so you order them? I noticed they have a camber ball joint for the front as well...
Old 09-20-2010 | 08:36 PM
  #37
Vitt's Avatar
You can find many on ebay. I think this place could also order the S2000 pieces for you. He carries Hardrace parts but seems to stock mostly for Civics and Integras: http://www.specialprojectsms.com
Old 12-03-2010 | 01:38 PM
  #38
LeonGalt's Avatar
Where is the info on the Asura monoballs?
Old 12-03-2010 | 04:27 PM
  #39
PossumK's Avatar
https://www.s2ki.com/forums/index.php?showtopic=731390
ayellows2k
06-28-2017 03:56 PM
boostin serge
12-07-2011 03:38 PM
boostin serge
05-24-2011 06:25 PM
ssms2k
06-28-2008 12:23 PM
eglogic
02-27-2007 06:20 PM
Quick Reply: Any affordable control arm bushings?
