Alignment question
Old 04-12-2010, 12:09 PM
robinson's Avatar
Originally Posted by 124Spider,Apr 12 2010, 01:39 PM
Again, suit yourself. As expensive as tracking a car is, I can't imagine seriously compromising the handling in order to save (perhaps) a little on tires, over time.
You will regret it if you do this.
Honestly, since I've done track days and autocross with a square setup, you really need to change something before you just slap these wheels/tires on and hit the track. I don't think you would be happy with a "compromise" alignment solution to make this setup work.
Old 04-12-2010, 12:30 PM
miamirice's Avatar
OK robinson, you have a square set up on a 2004 and you track, not autocross. Fantastic, I would like to hear from you on your set up as its Relavent. Lets bring this back to the intended purpose of my post.
AS A STARTING POINT, what alignment do YOU recommend based on what you have? I AGAIN intend to move to an adjustable coilover and front swaybar. I am simply trying to move up the time line of dialing in the car. I spent 4 years finding my set up on the m3. Just looking for a good starting set up.
Thank you.
Old 04-12-2010, 12:36 PM
robinson's Avatar
Well...I don't track anymore, but I used to run with a large front sway bar on full stiff, no rear bar, and lots of neg camber front and rear, zero toe front and about 1/8 in toe in rear.
For you, I'd go with more rear neg camber, whatever you can get, and maybe -1 deg front camber.
What you need to do is balance out the added front grip. Removing the rear bar is/was not smart without a corresponding chagne to the rear spring rate, so I'd leave that alone, but as a last resort it will result in more rear traction, with less rear roll stiffness.
Old 04-12-2010, 01:02 PM
miamirice's Avatar
I was also thinking a slight toe in for the rear might help??
Old 04-12-2010, 01:16 PM
psychoazn's Avatar
I track on a non-stagger setup with stock suspension.
As for understeer, alignment alone will change that.
Most s2k challenge guys run non-staggered tires; there's not really any correlation between having coils and running non-staggered tires.
A common "proven" setup is non-staggered tires, coils with non-staggered spring rates, and a large rear spoiler.
Old 04-12-2010, 04:01 PM
SILAP1's Avatar
toe in rear will help a bit .
jadebellyt
04-26-2015 05:29 PM
Rs_evo8
05-25-2009 02:24 PM
foz01
05-26-2005 09:59 AM
MagicDave
01-05-2004 09:35 AM
docofmind
10-22-2002 02:21 PM
Quick Reply: Alignment question
