Alignment or Corner Balance first?
Old 02-06-2009, 03:50 PM
DCIdevil's Avatar
Default Alignment or Corner Balance first?
which one do i do first?
they both kinda have an effect on each other, so which one do i do first with little effect on the other..
thanks
Old 02-06-2009, 04:20 PM
Administrator
krazik's Avatar
if you're only doing 1 the alignment. no question.
if you're asking the order to do both of them, corner weight then alignment. alignment shouldn't change your corner weights.
-Ry
Old 02-07-2009, 02:16 PM
-outkast-'s Avatar
personally, i do corner balance and then align. too bad ur not in my area, i corner balance for cheap
Old 02-07-2009, 07:53 PM
terahertz's Avatar
yea i need to corner balance again blue lol.
Old 02-07-2009, 10:59 PM
-outkast-'s Avatar
hypermax iii FTMFW!!
Old 02-07-2009, 11:49 PM
buggy1129's Avatar
its corner balance then alignment. Usually its done in the same day, most shops that can do corner balancing can also do alignment.
Old 02-08-2009, 12:42 PM
PDS
PDS's Avatar
I would recommend doing the alignment first and then a final corner weight. Caster adjustments have a huge impact on corner weight.
Our race team always does a rough corner weight - based upon static measurements then the alignment and finally full corner weighting.
Another way of looking at it - raising or lowering spring perches a few turns has a minimal effect on alignment whereas a small change in caster has a large effect on corner weight
Old 02-08-2009, 02:32 PM
DCIdevil's Avatar
so now i'm confused apparently there is no definate way??
most of you say corner balance then align. PDS makes sense but he says align then CB.
is there no set way of doing this? it's just opinion or what?
Old 02-08-2009, 03:01 PM
EternalLx's Avatar
My shop does both at the sametime. He goes back and forth adjusting both as one changes the other till everything is spot on... takes about 2 - 2.5 hours.
Old 02-08-2009, 04:10 PM
Administrator
krazik's Avatar
I think your guy is pulling your leg. How does an alignment change your cw?
Quick Reply: Alignment or Corner Balance first?
