aerodynamics - wing position
The image above shows the wing on top (fully exposed to the oncoming air) & a wing that is positioned just right behind the body).
I'm guessing that the wing positioned above would have more drag than the wing positioned behind the body. Correct me if I'm wrong..
But what about the downforce? Which one has more downforce? (they are identical wings).
I came to wonder about this because the BTCC civic hatchbacks use a wing that is positioned behind the chassis, whereas J's racing / Memory Fab have wings that are positioned right above the chassis. How do they differ?
any speculations?
I'll give it a shot. The wing that is in the cleanest air flow will provide the greatest amount of downforce. Now, I would assume (oops) that the first illustration meets that criteria.
I will also speculate that the BTCC rulebook dictates the position of the wing on the second example.
I'm not an aerodynamicist by any stretch of the imagination, but...
The second wing -- downstream of the car -- would be in a lot turbulence. I don't think you'd get any meaningful downforce out of it all.
Above the trunk. you still don't have the cleanest possible airflow. The cabin disrupts it, and the characteristics of a soft top makes it even worse. But it's the better of the two you are considering.
A common misconception is that if your wing is higher than the roofline of the cabin, then the airflow is clean and parallel to the ground. That's not true. 20-odd inches above the decklid of my car (not an S2000), the air is still moving at a 12 degree angle. You've got to get VERY high up before the air is no longer conforming to the shape of the car as it moves.
VERY high.
VERY high.
And actually, with the hatchback design, you really aren't talking about wings in those two examples. The second would be useful as a spoiler, although not as useful as a functional wing, which you've got with the first example.
Drag isn't a huge issue, even with what are considered low-hp or momentum cars. At least, not at most tracks.
VERY high.
Originally Posted by mikegarrison' date='Jan 10 2009, 01:10 AM
It's more accurate to say that maximizing downforce is more important for laptimes than minimizing drag. But that's not quite the same as saying drag is of little importance.
speaking of a hatchback, isn't there a vacuum behind the hatch which basically "slows" down the car? I guess I can say it pulls the car back? It seems like the air passes through the car itself and all of a sudden has to fill this giant space right past the hatch.
Originally Posted by Voodoo_S2K' date='Jan 12 2009, 08:11 AM
It was my understanding that hatchback designs like the CRX, Insight, and Prius with abrupt ends are better for aero.
The goal is to try and have the flow going past the end of the body moving straight, with little or no abrupt turning into the stagnant zone behind the body.
Originally Posted by mikegarrison' date='Jan 12 2009, 08:16 AM
Look up boattail. There are subtleties involved here, as with most aerodynamics.
