255 Square Setup Stock 01
Old 03-24-2015, 10:04 AM
nrcarone's Avatar
Default 255 Square Setup Stock 01
I'm thinking about running a 255 square setup on my 2001 AP1 with stock suspension except for a comptech front bar in STR this year. Is front fender rolling required for these tires?
Old 03-24-2015, 10:24 AM
gptoyz's Avatar
Depends on the tire, wheel and offset
Also "fit" is going to be a relative term
17x9 +58 is going to be a minimum to fit
17x8.5 +54 is the minimum for an 8.5
If you are going for the popular 17x9 +45 you are going to need a roll and pull
I don't believe camber being a tool to fit tires. Camber should be an independent available tuning option per track/condition; not a requirement
Also regarding camber are you pushing the track out via an offset lower ball joint (ie Megan, hard race, Js and spoon) or are you pulling the upper a arm in a la SBC? Leaning the tire in with the SBC will give you fenders more clearance and expense of possible rubbing on the control arm (again depending on wheel offset)
Old 03-24-2015, 10:32 AM
scottdh20's Avatar
look at tirerack. iirc you cant roll fenders fenders in str ... 17x9 +60(or higher) with a 255/40 will fit without any fender work. there is a few options out there for that sizing cheapest being the tr motorsports wheels
Old 03-24-2015, 10:37 AM
nrcarone's Avatar
I was looking at the TRM wheels 17x9 with a +63 offset
Old 03-24-2015, 10:38 AM
nrcarone's Avatar
Would bending the fender tab be required?
Old 03-24-2015, 10:39 AM
Conedodger's Avatar
Fender rolling is STR legal. You can't pull or modify the outside profile of the fender.
Old 03-24-2015, 10:42 AM
Conedodger's Avatar
I ran 245s on the OEM front wheels and springs without fender mods. I went to 17x9 +63 and 245s on Eibach springs and was getting into the tabs pretty hard. When I went to the Ohlins DFV shocks, I rolled the fronts.
Old 03-27-2015, 07:29 AM
Xene's Avatar
What ride height do you guys use for front and rear of car? I plan on buying the Enkei PF01 17x9 +60 mm offset wheels with 255 tires. I have front camber joints to increase negative camber. I would like to only do the fender tab roll to allow clearance.
I have just been trying to research the old archives but I get conflicting data on whether you need to roll your fenders or not for ride heights of 12.75 inch or higher.
I want to get the information first before I dial in the ride height of my Ohlins DFV shocks.
Old 03-27-2015, 07:40 AM
Conedodger's Avatar
I can't remember my ride height off hand, but I want to say 13.25? I have offset ball joints in the front, running -2.75 camber. I had to roll the fenders.
Old 03-27-2015, 08:02 AM
KaNgArOo's Avatar
Roll the fender tabs in the front at least. You will rob the inner wheels on the upper control arm with 17x9 +60. and also the outer edge fender liner.
Quick Reply: 255 Square Setup Stock 01
