2400 lbs +/- with cage and sc?
#41
Exhaust system is a header, short pipe, 9 inch wide by 14 inch long stainless muffler, short pipe and then a turn down. It ends under the car. All tubing is 2.5 stainless. With open car SCCA allows exhaust to end under car, but must be rear of halfway between the wheels.
For most a SCCA races the noise limit is 103 db, thus I am well below that limit. When I tried a 4 inch round muffler at Lime Rock at a muffled LRP club day, it was over the noise limit. Not sure if it under there with the current bigger muffler.
Some have suggested it is louder exiting under the car.
#43
i drive the blacktrax ap1 test mule. its 2350 lbs (no driver, 1-2 gallons of gas) its fully caged, no abs, modified oem harness, no lights, no spare tire well, fiberglass mugen style top with lexan window. none of the original structure was gutted, a pillars and center console are still intact.
#44
#46
#48
My muffler is a Magniflow stainless steel from Summit. It is about where the stock cat would be. I should have the specs at home if you need details.
Not sure who you were asking about SCCA region. I am an NNJR member, but race with any region.
