2015 NASA TT Setup
Old 01-29-2015, 06:09 PM
  #111
s2000ellier's Avatar
Chi's AP2 TTC reclass was 214whp / 2755lbs
Old 01-30-2015, 09:31 AM
  #112
nbauti2's Avatar
Just got my AP2 reclassed:
TTC: 217hp @ 2795 lbs
TTC*: 217hp @ 2715 lbs
Ratio's pretty in line with you, Pat. I'm pretty comfortable with my current setup with front splitter but would be fun to run mods virtually identical to you in TTC* trim minus suspension. We'll see after some testing.
Old 02-06-2015, 04:33 AM
  #113
No.Division's Avatar
I do think its interesting that Dysen's TTC* reclass put him at 12.0 with the final class being TTB and even my reclass to base class TTB is 12.43. At the TTB level does the CR really have that much of a build advantage over the standard AP2? Will be interesting when I get the car back together to see if I can catch him!
Old 02-08-2015, 03:12 PM
  #114
Just got my reclass.
TTC 216whp @ 2780 == 12.87:1
TTC* 216whp @ 2700 == 12.5:1
2001 AP1
This was request with 210whp with a 3% variance
Old 02-09-2015, 10:40 AM
  #115
Zip Tied Suzuka's Avatar
2001 AP1
What all "power mods" do you have, and did you just take your car to a Dyno?
Old 02-09-2015, 12:00 PM
  #116
I installed ITBs. The car previously had 70mm exhaust + TP
I had the dyno sheet from tuning the ITBs
Old 02-09-2015, 12:13 PM
  #117
Ok thanks
Old 02-09-2015, 05:40 PM
  #118
Andrie's Avatar
Hoosier A7 is the fastest DOT tires for sure. However, Hankook C71 is not far behind. I tested both of them last year and I can definitely confirm they are not that much apart. I was seriously considered running C71 at the runoffs last year.
Old 02-09-2015, 07:48 PM
  #119
DTP525's Avatar
Andrie, within the NASA TT crowd, specifically TTF-TTB, the A7s are worth too many points to run. It looks like the R7 is one of the best tires to run for contingencies. But how would you rate the C71 vs R7?
Old 02-10-2015, 06:53 AM
  #120
Mahjik's Avatar
Dysen, I ran the Hankooks most of last year (C51 & C71). I think the Hoosiers are still a faster tire, but the Hankook's do last longer (and they are cheaper). I don't think the Hankooks are that far behind Hoosiers, but given equal drivers the Hoosier will win. They have similar characteristics has the Hoosiers so you could use those as warm-up tires and then your Hoosiers for your money run without having to re-adapt.
