2.2L Motor Failure Due To Detonation.
Old 11-19-2009, 08:07 AM
  #41
rob.ok's Avatar
Bill,
The car was tuned in 100 and I never used any regular pump gas in the car. I even drained all the old 91 that was in the tank to make sure that the new motor started up on fresh 100.
-Rob
Old 11-19-2009, 08:27 AM
  #42
Administrator
krazik's Avatar
When you get back on the saddle, go see shad. He'll make sure you run right.
Old 11-19-2009, 09:44 AM
  #43
AlexS2200's Avatar
Location: 13851 A Better Way #11D, Garden Grove, CA 92843
Hi Rob,
I have a question regarding your EMS Tune and your expired engine at Button Willow.
How did you compensate for elevation on the EMS since the AEM ECU does not have a barometer?
Did you run the car and then adjust the AFR while at the track in between sessions?
BlacTrax is located in Milpitas, CA at 16ft elevation
http://en.wikipedia.org/wiki/Milpitas,_California
Button Willow, CA is 269ft elevation
http://en.wikipedia.org/wiki/Buttonwillow,_California
I ask this because I have experienced issues with EMS not running correctly due to the elevation change. However, I do not know if this relates at all to your engine failure.
Old 11-19-2009, 10:40 AM
  #44
Administrator
krazik's Avatar
LOL you're worried about 250 ft?
What about the difference between the top and bottom of laguna seca?
Old 11-19-2009, 12:30 PM
  #45
AlexS2200's Avatar
^LOL I guess you are right. I always see a difference in performance from where I live in Chino Hills to Button Willow. The difference is a little more, about 800 ft difference. The only reason why I was asking is because of the EMS issue with elevation, but I didn't really realize the common sense aspect relative to what I was asking. Ha Ha Touche
Old 11-19-2009, 12:38 PM
  #46
Antonov's Avatar
Doesn't AEM use manifold air pressure and temperature, along with many other parameters in order to compensate for differences in conditions, the reason why Alpha-N sucks....
Old 11-19-2009, 02:16 PM
  #47
Stratocaster's Avatar
IIRC, AEM EMS does have a barometer. It it internal.
Old 11-19-2009, 02:50 PM
  #48
Banned
wadzii's Avatar
the knock data there is worthless.
that parameter gives you knock filterd by crank tooth. something internal logging isnt fast enough to pick up.
  #49
Banned
wadzii's Avatar
for anyone reading, the PROPER channel to read to get actual knock noise, unfiltered, is knock raw, NOT knock volts
Old 11-19-2009, 04:54 PM
  #50
rob.ok's Avatar
Jason,
I'm sorry but I'm slightly confused as to what your are trying to say. I'm really sorry but I'm trying to understand but damn this stuff is confusing.
I know you broke it down but can you give me a more direct answer? Is the knock value shown above just worthless or are you actually alluding to the fact that the graph might actually be showing knock?
Thank you!
-Rob
Quick Reply: 2.2L Motor Failure Due To Detonation.
