Walbro 255 w/ Stock ECU
My car had a greddy turbo kit on it previously. Too lazy to swap out the 255 walbro fuel pump when i went back to stock. Would having the fuel pump cause any adverse effect on my motor?
Have you seen any data that shows the stock FPR isn't big enough to bypass enough fuel to not change fuel pressure with a 255lph?
Or is that just your opinion?
Also, OP, you are aware there are two very different styles of fuel systems for an S2000 right? So shouldn't you specify which one you have a question about?
Originally Posted by s2000Junky' timestamp='1443652756' post='23762569
No not at all.
This is based off a MY 00-05
Nope, the stock ECU will still mandate the correct amount of fuel to put into the car. Leave the Walbro in there, you don't need tuning on a fuel system until you start fussing with injectors.
I had my Full Blown 290lph fuel pump in my car for months before getting the car tuned with a turbo. Made absolutely 0 difference.
Edit: Dropped a letter.
Forgot to mention that I have an MY02. The only thing I didn't like was when I took the car down to Homecoming 3 (6hours), the fuel pump was noisier than usual even with a full tank of gas. Thanks for your guy's answers!
Originally Posted by shind3' timestamp='1443722613' post='23763419
[quote name='s2000Junky' timestamp='1443652756' post='23762569']
No not at all.
No not at all.
[/quote]
Sure, but if I could get my fuel trims closer to 0 and not have to run richer than I need to at WOT just by changing to a stock fuel pump, I would.
And if the FPR is big enough to bypass the extra flow from a Walbro 255 then yes it will not be change anything except for some warmer fuel. I asked if you knew the FPR was big enough for this to happen without raising fuel pressure especially at idle.
But the 06+ have a different FPR. don't know if it can bypass the same as the earlier ones.
So the answer could've depended on that variable. But the engine itself will fine fine, yes. And I guess that was the question. You win, lol.
Walboro 255's are noisy. Other larger aftermarket pumps are not. I run a FB340 (with a stock ecu) its pretty quiet.
Originally Posted by s2000Junky' timestamp='1443743836' post='23763779
[quote name='shind3' timestamp='1443722613' post='23763419']
No not at all.
No not at all.
[/quote]
[/quote]
Short and long term fuel trims fluctuate, they are never just at 0 all the time no matter the fuel pressure. However if centering them close as possible is your goal/concern, pick up an adjustable fuel pressure regular and bring it back to balance. Of course this is all on the premise that the fuel pressure has indeed changed with a bigger pump and stock fpr, which I don't recall seeing. Yes, I do win
