Toda ITBs installed
#72
MaDara that is a sweet looking setup. Is your tune TPS-based/alpha-N or MAP-based? Where is Autowave located and who was the tuner? You have 75whp over my Jenvey ITB setup, and I was also tuned on a Dyno Dynamics. I would HOPE that some of this is attributable to a difference in altitude and dyno correction factor used, and I am certain my car requires more tuning. I have a Berk header and a larger exhaust with a test pipe.
How does the car run when not at WOT? Are you happy with the tune? Obviously you can't complain about the power output!
#73
That brings up a question though, does the IAT sensor mount in one of the horns?
#74
You can see MaDara's zip tied down down below the intake (right mid in his large photo). With the Jenvey setup you can mount it on the filter housing.
#75
#76
Ahhhhhh good to know! Thanks for that info.
#77
http://speedhunters.com/archive/2011...oon-nsx-r.aspx
Anyone good @ photoshop? Am thinking about blue-anodized velocity stacks. Anyone want to to help?
#78
Member
Just checking if you still run the Toda ITBs?
Would love to know if you saw any performance drop using the filter socks?
I may be looking at Toda ITBs and wondering if you still need separate IACV / brake booster block or if it comes with it?
#79
#80
I would concentrate more on getting a vacuum box that can a keep strong and consistent MAP reading than a super expensive tube with a new IACV unit.
Specially if it's more for a race car like I think yours is MB?
