S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Test pipe
Old 08-27-2011, 01:06 PM
atlasshrugged's Avatar
Default Test pipe
I'd like to replace my cat with a test pipe. I have an oem header and exhaust and would like to add a test pipe for the sound factor. What size is recommended? Is there a test pipe that fits both the oem header and oem exhaust? Thanks For any help in advance.
Old 08-27-2011, 01:54 PM
JUSTINTHECOASTIE's Avatar
63mm but ppl like 70mm
searchin' aint never hurt nobody
https://www.s2ki.com/s2000/topic/636...t-pipe-thread/
Old 08-27-2011, 04:25 PM
wisdom's Avatar
Size of test pipe depends if you plan on changing the exhaust.
Old 08-28-2011, 07:27 AM
Thanks, but this tread doesn't really answer my question. Are you saying that 63mm is what mates to the oem header and oem exhaust?
I have no plans to change the exhaust. I just want a test pipe that will mate with my oem header and oem exhaust.
Old 08-28-2011, 01:08 PM
Yes
Did you really read that thread or browsed through it? Good luck Justin
Old 08-28-2011, 01:09 PM
OP said he has stock exhaust
Old 08-28-2011, 01:42 PM
suzuka-blue-s2k's Avatar
All test pipes for the s2000 will mount up to the stock exhaust regardless if it's 60mm, 63mm, 70mm, ect.. If your planning on keeping the stock exhaust get a 60mm one since that's the size of the OEM exhaust. I had a 60mm Invidia test pipe with CEL fix on my S and loved it.
Old 08-28-2011, 01:50 PM
Thanks for the help But, thanks most for answering my question with out any snobbery! for you sir.
Old 08-28-2011, 02:00 PM
Oh dude, I wasnt snobby I was nice about it,if you posted this question in that thread you would have gotten more replies and opinions...but anyway which did you decide?
Old 08-28-2011, 02:48 PM
^ Its all good. I got what I need here. I haven't decided, but I'll likely go with the 60mm.
Quick Reply: Test pipe
