test pipe?
test pipe?
sup again!
05 ap2 with full bolt-ons and a apexi neo tuned to 211.2 and 150.2 with the stock cat..
will a test pipe give me more power?? i keep hearing rumors about people loosing power in the mid range with a test pipe.... is it true??
thanx for the help...
no, you will gain power.
Consider a high flow cat, it makes about the same power (-1 hp or so)
you will also need to retune, because it will lean out your car a good point
Has anyone discussed the long-term fuel trim ramifications of a TP? I've searched and didn't see a whole lot. Sure, an initial dyno will gain power due to the LTFT being @ the settings for a cat, but is there proof of sustained gains from a TP??? I'm concerned that as the ECU learns that any gains would be lost.
Anyone tuned who changes something to do with the engines performance (in this case installing a TP) should get retuned to truley reap the benefits.
IMO retune is a must
You will gain a small amount but not much, the stock CAT is a highflow to begin with.
Highier flowing CATS IMO will add next to nothing on the F20C or F22C n/a wise.
