S1800?
#31
Originally Posted by AnthonyD1978' date='Jan 23 2009, 05:05 PM
just throw a turbo hayabusa motor in the s2k...
http://thekneeslider.com/archives/2005/02/...busa-v8-engine/
http://www.youtube.com/watch?v=cV4HdsDZX6c
is this possible?!??!?!?!?!
#32
Originally Posted by moogleii' date='Feb 1 2009, 02:59 PM
I agree, but I've always assumed it was relative anyway. They don't need torque compared to a heavier beast, but if your fellow F1 competitor is running 200-300 ft-lbs, and you're only running 100, you're gonna need more torque because it'll probably cost you the race otherwise.
but back on topic with the whole destroking thing bad idea. if you want to get most out of your F20 or F22 you need to go bigger. if you squeeze an orange hard enough you will get out a lot of juice but you will start destroying the orange. if you get a bigger orange you can get the same amount of juice but not destroying it. if you are wanting to de stroke to get more revs out of the engine then just get the bore and stroke close to the same size. you will have revs and power
#33
^^ Do you seriously think that orange juice and horse power are relative? That is a horrible analogy. Your thinking is flawed... the F20C is slightly under-square (87x84) and the F22C is slightly over-square (87x90). By your logic.. a perfectly square (87x87) would rev higher than an F20C???? No way.
LostMotion is one of the few who actually understands this concept. The ideal setup would be a larger bore (allows for larger valves=more flow) and a shorter stroke to keep piston speeds down to a safe level. If my goal is a higher revving motor, I MUST reduce the stroke. Will it lose low end power? Absolutely! Would it hinder daily drivability? Absolutely. Would it have a smaller and pointier power curve? YES! that is my goal, NOT MAX POWER. Would this power curve, coupled with a lightened s2000 be the funnest thing ever? HELL YES. Why would I want to do this? for the same reasons that I prefer an F20 to an F22
#34
Flame on Johnny Storm!!! if you just want to be a dumb ass and go rev happy just throw a phucking ZX14 engine in your S just dont hurt the F20 by de stroking it.
use your bad ideas on like a b18 or something dont phuck up Gods perfection
#36
I am just so happy that you saved me $4k and 2 years to learn about orange juice.
#38
Originally Posted by ArchAngel2K,Feb 4 2009, 12:31 AM
and your reasoning for what it is you want to do is stupid as hell.
think about my logic for a second and it will make perfect sense
Now you can't rev to 20k in a street car. Traditional valve springs fail at 12k (drag racing applications excluded) and you should have a margin of safety on the road. So you won't want to rev past 11k at the highest. You just need to figure out how much you need to destroke to keep the mean piston speed the same as the F20C at 9,400ish RPMs.
You're right that this destroked motor may not be very reliable. But considering the reliability of the average stroked motor I'm not sure he'll be losing anything.
#39
The stock mean piston speed is 25 M/S. Assuming you were willing to increase this to 25.5 M/S, you would need to destroke the motor to 70mm in order to rev to 11k which would give you a displacement of 1,741cc.
By the way 1,741cc is 0.000480589278266 cords of firewood.
