Are RDX injectors on DBW s2k pnp?
I did a search and found nothing but since that the fuel rail is different vs the non dbw s2k I was thinking it might be an easier swap. I want to avoid clip adapters and spacers if possible.
No they're not I have a '06 DBW and I already looked into this, look at post #3.
https://www.s2ki.com/s2000/topic/834...tle-injectors/
However I could have been misleaded, if anybody else knows otherwise please chime in.
Cheers
Cheers
Banned
rdx injectors use a 14mm o-ring. not sure what size the dbw injectors are but the pre-dbw rail is drilled for 11mm injectors and the rail isnt wide enough to even drill out to a 14mm o-ring.
if you get the adapter pieces rdx injectors fit perfectly in a dbw intake manifold if you use the ap1 pre-dbw fuel rail studs.
Banned
http://www.xenocron.com/rdx-injector...69aa22cb24baa0
these allow you to use the stock fuel rail, but make the injector a little taller.
Banned
rdx injectors dont plug in, but you can take the pins out of the factory injector plugs and put them in the rdx plugs so you dont have any "extra" parts other than the adapters for the o-rings
Banned
http://www.xenocron.com/rdx-adapter-...nda-p-532.html
thats everything you'll need minus the non-dbw fuel rail studs
That would work. I have had too many issues with the pnp clips and I don't like hacking up harnesses.
