S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Private Label Header Test + Dyno...
Old 04-04-2010, 06:46 PM
  #251
Neutered Sputniks's Avatar
Originally Posted by myslow1,Apr 4 2010, 09:19 PM
I dont have any of the things you mentioned... It had a leak but I fixed it.
So, you did actually have the problem most everyone has posted they had/have with the PLM header. You just managed to fix yours.
Old 04-04-2010, 10:39 PM
  #252
Civicvtec1ps's Avatar
Just use oem gasket instead of provided plm gasket.
Old 04-05-2010, 04:25 AM
  #253
josh7owens's Avatar
whats the wieght difference between the PL and the stock header
Old 04-05-2010, 06:00 AM
  #254
drewmob's Avatar
weight difference between oem and ANY header is about as much as taking a good poop. ridiculous question is ridiculous...
Old 04-05-2010, 06:17 AM
  #255
Requiem's Avatar
The header seems quite a bit lighter. There are no heat shields on it and I think the PLM is stainless which also might be lighter, but I'm not certain.
I also have the same problem as I started another thread about the PLM leak. Not a big deal. I swapped on the stock one and it lessened the leak a bit. However my donu gasket has 95k on it and is 10 years old. I'm going to order a new one today. That should hopefully fix the leak.
Old 04-05-2010, 06:24 AM
  #256
BeefMan's Avatar
Just to clarify, which gasket are we talking about? The gasket between the manifold and the block or the gasket between the manifold and the cat? or both?
Old 04-05-2010, 06:30 AM
  #257
AngryTurtle's Avatar
The reason the PLM header leaks is the the doughnut gasket sits flat to the flange where in the oem header there is a 1/4inch or so of a tapered edge before the flange that the doughnut gasket seals to. This makes it seal better and sit far enough from the flange that the 2 flanges cant touch before the round part of the gasket is seated in the cat.
Old 04-05-2010, 06:49 AM
  #258
drewmob's Avatar
d-gasket between the header and cat. i think the issue is an imperfection in the angle of the header. even with the new oem gasket the angle is slightly off. i made mine work as seen below. just replace the bolts with something that can be snugged up a bit more and you're good to go. DO NOT tighten all the way, you need some flex there.
fwiw, my attention span with this thread has waned. i believe all the necessary information has been provided in the 11 pages. redundant posts are redundant.
Old 04-05-2010, 07:30 AM
  #259
BeefMan's Avatar
That is one hell of a gap, if that's the type of quality I can expect from this header i think I might be sending mine back. I'll open it up and have a look once it arrives, still on the fence here.
Old 04-05-2010, 11:43 AM
  #260
no, see above. Look at your oem header.
Quick Reply: Private Label Header Test + Dyno...
