port and polish f20c head
#21
got f20c with with 42k i bought from honda like it is just no intake mani or valve cover but besides that complete
300 shipped if you want i paied 400 but dont need i blew motor so i am using that head now
#22
im building all motor setup should i port and polish the head everyone is saying not to take any material off these heads it ruins them and loss power.i was reading they said dont port it just give nice polish but local machine shop who builds alot of v8 he does good port work everyone says and very good price im just scared to port it and end up losing power what should i do
thats just my 2 cents, good luck.
#23
Banned
if you weld up the quench pads on these heads and you arent careful you'll end up with the pistons hitting the head, they stick out 0.010 over the headgasket. That also doesn't do much for deshrouding the valves. If you are going that far its better to mill the crap out of the head and use a thick headgasket to get proper piston - head clearance.
#24
it actualy does alot on a N/A motor, if it comes out of the hole .010 and the gasket is .030 he will be fine. just weld it then surface it and blend the thing and give it a short turn and punch out the pockets, it will be good enough, let me know if im wrong
#25
Enlarging may gain cfm but will drop velocity
Great flowbench numbers don't equate to a great head
#26
#27
Originally Posted by s2k_2fast4u' timestamp='1312584868' post='20852284
[quote name='s2k210' timestamp='1311036641' post='20792062']
[/quote]
I agree with that statement. To do other wise would be little different from taking a Telsa to a nitrous shop to prep for the "big race".
#28
i gave you my opion, it your money and time so make the best desion for yourself. and i am rite, you are somewhat rite about the flow numbers but there is alot to gain from a head that flows better, unless you boost it then it doesnt make that much of a difference. I paid alot for my knowledge, so this is the end for me on this discussion.
just trying to help thats all, not looking for a heated debate
#29
Banned
the piston comes out of the hole 0.040, the gasket is 0.030, the piston sticks out over the GASKET 0.010
#30
polishing isnt the best... the best is to create a golf ball texture to the ports so the air rolls at the surface of them, making this air rolling effect will significantly help the air to roll on air creating a faster flowing vortex and not a slow down from metal surface where the flow loose its efficiency. polishing or porting a s2000 head is very disputed , some say its good , others dont, personnaly i think that a 2.0l engine develloping 240hp is really good in its stock form, and I dont think spending money on only a port and polish job + valves job will significantly make power on a N/A form. I havent seen cams changing much in N/A form too. IMO The best a N/A s2k motor can have is a bump in displacement, a set of ITB's or a CAI ,a non restrictive exhaust, some mods on the inertial mass (lightened flywheel, alloy pulleys, A/C delete, P/S delete etc...) and a very good tune up.
