OBX ITB Kit! Pictures
#121
I did baseline dyno but i don't have the graph for that
I have my torque and power graphs I will be uploading them today
The dyno was a Dastek Dyno which is popular in Europe.
I'm sure it is like a Dynojet since stock cars read between 195-205 whp depending on engine health
#125
I also make my Idel air control valve work. car idel around 1000rpm now. car should be dyno tmr.
hope I can get some good power !! also do u have any problem wiht rain so far?? I am thinking makeing
a filter for the itb.
#129
My link
Finaly tuned my car!!! making 202whp. my car have comptect exhaust ,megan test pipe and aem ems.(thinking about getting J's 70 mm exhaust so I can get more power)
As for IACV u need buy a aluminum block, on the back of IACV there is 3 big hole one is for water (no use), 1 suck the air in and a go to the air block on the bottom of the ITB. ( IACV is like a TB for idle because when ur ITB is close there is no air go in to engine to idle, so the valve open when u idle and close a little when ur water temp warm up.) there is a big allen key bolt in the fornt of OBX air block , it is 3/8 NPT go homedepo buy 90 degree fitting and step it up the 1/2 NPT pipe. coz u need a big hose go to IACV . REMEMBE U NEED A ONE WAY CHECK VALVE IN BETWEEN THE HOSE OR U WILL LOST THE VACUUM IN THE VACUUM BLOCK!!!!!! ALSO WILL LOST UR BRAKE!!!! I WILL TAKE MORE PIC OF MY SETUP!!!
here is some for IACV PIC
#130
just did a compression test today, 175 all 4 cylinder....... not bad but low millege engine should have about at 220 psi. but my motor
have 91k mile now. so I think it is normal. still happy with 202whp, my tuner told me if compression is good it should make another 15 plus hp!!
