S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
NA setup with AEM EMS
Old 05-04-2009, 01:03 PM
tsoshi2007's Avatar
Default NA setup with AEM EMS
Hi guys i have got my exhaust and intake setup for a while and now decide to refresh it with AEM EMS. here is my current setup: J's carbon intake, T1R header (new version), J's test pipe and J's 60RS single. i wonder how many gains or number i could probably get with a good tuner? i've heard that people with NA setup with AEM EMS does not gain too much..like 6-8 whp? and mostly at mid range but minimal at peak. my goal is about 15 whp hopefully. is it possible?
thanks guys
Old 05-04-2009, 01:36 PM
Ian300D's Avatar
Well if you figure in the added weight you can get rid of by switching maybe it will feel like that much.
Old 05-04-2009, 01:41 PM
devs2k's Avatar
wrong forum...
but, when I was NA, I had t1r 70mm with test pipe, j's header, K&N fipk, and was tuned with the emanage ultimate. On my tuner's dyno, peak whp on stock ap2 is 220whp. With the mods I had about a peak whp figure of 247 or so, and ran a 16:1 AFR at 5000-6000 rpm Tuned, I had 250whp of peak power. So I picked up 30whp from those mods.
But the real difference was in the midrange, where I picked up 5-25 ft lbs of torque between 4000-6000 rpm.
Old 05-04-2009, 02:09 PM
tsoshi2007's Avatar
oops....wrong forum...
so you got 220 whp with stock ap2 and 250 whp with the mods? sounds a little too high to me tho. i haven't dynoed my car yet but from what i know people usually get around 200 whp with stock car.
Old 05-04-2009, 03:32 PM
HvRRZ's Avatar
Each car is different, so it's hard to just tell you what numbers you would make. I will say that with a good tune you will be over the 220whp mark, and could possible be near 230whp. I don't know much about the new T1R header(I don't think many do), so hopefully it performs as well as your other mods should to get some decent gains.
Old 05-04-2009, 04:32 PM
devs2k's Avatar
that is why i gave you before and after; the absolute numbers don't matter, only the delta, or the change from the baseline dyno to a tuned dyno
whether or not it went from 220 to 250 or 190 to 220, it doesn't matter... in both cases, the delta is the same
Old 05-04-2009, 04:38 PM
tsoshi2007's Avatar
sounds good. i will be satisfied with 220whp. and yea i will post up my result once i have it done
Old 05-04-2009, 04:39 PM
tsoshi2007's Avatar
oh okok my bad now i got it. so its about 20-30whp gain generally am i saying this right?
Old 05-04-2009, 04:45 PM
devs2k's Avatar
with your mods, yes it should be
you will also be able to drop vtec to about 4000 rpm
Old 05-04-2009, 04:56 PM
tsoshi2007's Avatar
vtec at 4000 looks too low for me as a DD. 5000 would be better isn't it?
Quick Reply: NA setup with AEM EMS
