My F20C/F22C build
My F20C/F22C build
well my motor shit the bed last night so now im gonna be pulling it and building it....
here are cliff notes
-bottom end is the problem
-it dropped oil pressure when i was driving for some reason
-pulling the motor next week to see the damage
-the car is still drivable and has very minimal knock...only under load
-head is perfectly fine
-yes oil was up to the top
-no it does not smoke under load or at idle
-suspect it was a bad oil jet that caused a worn main bearing becuase when it dropped to idle the oil light would flicker
now as for the plans for the motor
-F20C head
-F22C bottom end
-Spoon Headgasket
-Hondata Intake Manifold Gasket
-02-03 Ecu
-I/H/E
any suggestions will be much appriciated and help from knowlegable members, i also do not care for stupid comments made in this thread so i will probably ignore you if you post stupid obvious comment
now on to the pics
motor ready to be pulled out
thanks for looking
-F20C head
-F22C bottom end
-Spoon Headgasket
-02-03 Ecu
-I/H/E
now on to the pics
thanks for looking
Originally Posted by AP1FTW,Jun 1 2009, 12:51 PM
hmmm i was thinking about porting but didnt know what advantages it would yeild so i kinda discounted it....but does porting and polishing really help?
I would think that you will really need to watch your AFR's after building to make sure the extra displacement does not throw off the ECU; too lean. Or are you planning to use a piggy-back or stand-alone?
the only reason i am using an ap1 head is because the ap2 head i got with the motor is messed up......so i will need an AP2 ecu to run F20 head on F22 block? i thought guys are running full F22Cs on ap1 Ecu's and yes i was prolly gonna tune with a vafc II or afc neo
well i already have a 00-01 and ur probably correct since the 00-01 runs richer....i dont even know if the bigger bottom end will really gain anything we will have to see tho
