S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
k20/k24 swapped s2000
Old 02-03-2013 | 04:11 PM
MegaMan346's Avatar
Default k20/k24 swapped s2000
Hey whats up s2ki...just posting up a little sneek peak of my k24 frank swapped s2000. Almost 100% finished. I have one more tune session for my nirtous tuning and some adjustments. I have some more black anodized skunk2 parts to put on the motor. Plus im going to change up the suspension setup and swap rims. Its sitting on ap1 wheels and stock suspension with lowering springs so its kind of a sleeper in my area. More in depth build thread with more pics and videos coming soon. Will be adding stuff i miss on this post...enjoy
K-tuned and Skunk2 are the main companies that made this swap possible.
*Numbers: not going to throw exact HP/torq numbers out because rumors on the streets but barely 300HP and over 200 ft/lbs torq on first dyno session.
Planning to extract more on second session and start my nitrous tuning.
*2002 S2000*
-Head
prb-1 2005 type s head
supertech dual valve springs
supertech retainers
supertech keepers
stock ports
drag cartel stage 4 cams billet 8620
Golden Eagle head studs
custom Magnus intake manifold
skunk2 72mm throttle body
skunk2 black anodized vtec solenoid
custom fabricated matched intake with velocity stack filter
K-tuned thermo heat shield intake manifold gasket
K-tuned thermo heat shield matched thermo throttle body gasket
-Block
k24a4 block with papers 28 k when purchased ..
13:2 supertech pistons
tsx 2007 rods new oem dealer
oem bearings all oem clearence
oem crank
oem 2009 tsx tentioner
spunteck chain guide
oem tsx head gasket 87mm bore
k20a oil pump with correct chain guides and chain and gear all from a z1
k20 aluminum oil pan
skunk2 black anodized timing chain cover
K-Tuned oil cooler hose kit
-Fuel
currently tuned on E85
ID1000cc injectors
K-tuned fuel rail
K-tuned adjustable FPR with Ktuned fuel pressure gauge
Aeromotive 340 drop in fuel pump
-Transmission
stock with stage 2 ACT clutch with custom ACT flywheel
-Cooling
Mishimoto radiator
-Custom swap parts
custom fab exhuast manifold with black heat wrap, ran straight into a dual N1 titanium tip invidia exhaust
custom Innovative motor mounts and tranny mounts
custom fab tranny adapter plate
custom ACT flywheel
custom modified ap1 engine harness
K-tuned alternator relocation kit
K-tuned swivel thermostat housing
K-tuned custom upper hose housing neck
water pump auto belt tensioner shaved off to clear Magnus intake manifold
-ECU/electronics
Haltech platinum series standalone
NGK powerdex AFR gauge
Yellow top optima battery
***all tuned by DKGOODRICH.COM***
-one of the best tuners in the KY/TN area. Car runs amazing. Plenty of torq. Great smooth linear powerband. Very happy with the results on only the first tune session.
[YT]http://www.youtube.com/watch?v=6e__ZsyT-0c[/YT]
Old 02-03-2013 | 08:58 PM
nuk1ear's Avatar
hope to see more of these in the future. Did you say so far around 300whp?
Old 02-03-2013 | 09:25 PM
g0g3tt4's Avatar
Can you speak more on why you chose the parts you did and what your logic is behind it? And possibly do the same thing for the choice of power plant?
Other people will chime in, but I'd like to get your ideas because they are your choices. I'd appreciate it. Nice numbers by the way.
Old 02-03-2013 | 10:04 PM
nuk1ear's Avatar
NA wise, its easier to get power out of a K-series engine than the F series. And the rod/stroke ratio of the K24 means that the pistons and rods are not exposed to the same loads as the F20 at the same RPM so its generally more reliable at a given RPM compared to the F
The k series has I-VTEC, as we all know this is an advantage of the K-series engines also, helps a lot in the mid range. Theres just so much support for them and knowledge that its pretty straight forward to get reliable power from them i guess (NA wise)? Correct me if im wrong?
I wouldnt really see a point in going the K-series if you go forced induction, only for NA.
Old 02-04-2013 | 12:05 AM
datbino's Avatar
A few quick questions that don't have quick answers if I may..
How high do you spin the k24?
How 'expensive' is the swap?
How much wiring is involved?
Old 02-04-2013 | 02:37 AM
nuk1ear's Avatar
have you guys seen ballade sports swap kit? look it up. 3.5k for everything, including wiring adaptor to stock IP harness and exhaust mani to stock cat, inlet mani, everything basically that you need except labour and an engine lol
Old 02-04-2013 | 10:50 AM
SSS's Avatar
SSS
Why not just build a 2.4 or bigger f20 based engine?
Old 02-04-2013 | 12:53 PM
Bullwings's Avatar
See the previous posts already mentioned. Also, an f24c when revved higher to make more power doesn't last as long.
In my case, I'm also thinking of doing this if my motor goes, and it's mainly for cheap replaceable motors. It's a one time deal for future savings. If you track your car a lot - eventually it goes boom. A used f22c goes for around $3k. K20s go for about $800-$1000.
Blow two/three motors and you're more than break even on cost. Plus, it's much much easier to find and source k20/24. That would be my reason for doing this...
Old 02-04-2013 | 02:14 PM
08s2000CRbackinblack's Avatar
you basically can only do this on a ap1 correct? jealous of your setup, sounds like some serious parts and power
Old 02-06-2013 | 01:15 PM
MegaMan346's Avatar
exactly...anyone doing any kind of competitive racing will save money. the k series is alot cheaper to build. theres more aftermarket parts and support for them. alot cheaper to replace or fix if blown. you can find the motors everywhere. it makes more low and midrange powere.....i can go on all the advantages of swapping a k24/k20 into a s2000
