Installing Wideband sensor in High Flow Cat ?
I have an AEM wideband sensor kit to install on my ap1. Id rather not pull the header off to drill through it, so I'm thinking of putting the bung into the front section of the HFC, so only 3-4 inches from the end of the header. Any issues with me doing this in terms of accurate readings ?, if not then this would be my preferred installation area. Thanks for reading, and any replies on this.
Joey
Joey
What do the installation instruction say? A buddy just installed this (or similar sensor) in his AP1 (in preparation for a supercharger) and pulled the exhaust manifold for a neat installation near the front O2 sensor. I'm thinking that location was chosen to avoid the extreme heat of the catalytic converter. Placement needs to be as close to the engine as feasible and pick up all cylinders hence where it's positioned.
His engine bay is pretty empty at present and it was simple to drop the exhaust manifold out the bottom, drill and well the bung, and replace it.
-- Chuck
-- Chuck
Where ya gonna install it in a high flow cat? There's very little room in mine to put a bung. I'm mildly interested in an air/fuel gauge just for curiosity and to confirm the readings from the stock AF meter (AP2 engine has one).
<------------Front Rear----------->
-- Chuck
-- Chuck
-- Chuck
-- Chuck
I just want to know if my car is running lean or rich, maybe to a mild street tune with my Apexi NEO. , vtec has been lowered to 5300 so I'd like to see the AFRs in the new vtec range, along with all other rpms. Last season I got some afr's running on a dyno from the tailpipe sniffer after cat, but I didn't trust the readings with them taken so far back and after cat. I decided I'd rater use a wideband if I wanted to get some reliable information.
Let us (me) know how it works. I know the cat gets hotter than the exhaust manifold but don't know what temps the AFR sensor can accommodate. I'm reading the AFR off the AP2 sensor via my FlashPro and iPhone. The DBW versions use a AFR sensor.
I don't have a heat shield on my cat either . Highway rock (chunk of rolling concrete) hit it and broke the front tabs making the shields rattle. I'll try to reinstall it later this spring.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
-- Chuck
-- Chuck
