How do you know if you're 'over-camming' the motor
How can you tell if you have too much cam for the motor? Is hi-compression a must for high-lift, long duration NA cams?
All about the dyno... Motors react differently we recently had luck on an oem k24 motor with stage three cams...
That said make sure your valvetrain matches your cams cause that can cause trouble
