S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Gauges For N/A setup
Old 10-14-2008, 01:30 PM
03AP1's Avatar
Default Gauges For N/A setup
I am for sure putting a fuel pressure gauge on the rail. What gauges should I run inside? A/F, Oil Pressure, Vacuum, EGT, Coolant Temp, Oil Temp???
I want the best combo of gauges to protect my engine. I've been having misfire symptoms for the past month and think I have it narrowed down to faulty wiring or a bad fuel pump/filter. LMK what you guys think.
Also, are Autometer gauges worth the money since they are on the cheap end or should I invest in some quality gauges? I've searched but not too many threads on N/A gauge setups...
Old 10-14-2008, 01:33 PM
chimmike's Avatar
if you absolutely HAVE to have gauges, I'd say oil pressure, wideband o2 (innovate is my favorite), and maybe oil temp.
Old 10-14-2008, 01:35 PM
03AP1's Avatar
I am definitely not a gauge fan, but I do like having the information readily available when something goes wrong. Hate the overplayed piller mounts. I think I would like mine to be stealthy like the Rick's Radio Door gauge mounts...
I'll look into the innovate setups.
Old 10-14-2008, 01:45 PM
Js S2k's Avatar
Look into plx devices. You can use one gauge to display 4 different readings.
PLX Gauges
Old 10-14-2008, 01:46 PM
03AP1's Avatar
^^Was just reading a thread about their widebands!
Old 10-14-2008, 02:36 PM
LostMotion's Avatar
Oil temp and pressure and water temp.
Old 10-14-2008, 02:42 PM
HvRRZ's Avatar
Don't really need much else if you're staying NA...in fact you don't need any unless you're thinking about doing a lot of tracking.
Old 10-14-2008, 02:53 PM
chimmike's Avatar
even then I wouldn't bother with water temp, but oil temp and oil pressure.
Old 10-14-2008, 07:24 PM
Back S2k's Avatar
oil pressure. water rewmp and oil temp you dont really need cause you have a temp gauge on ur dash and if the temp increases it will show you. there is no nice place to put the gauge(s) in our car without it looking ricer(pillarpod) or tacky(radio door). Im just gona throw my one oil pressure gauge in the cupholder and call it a day.
Old 10-14-2008, 08:15 PM
LostMotion's Avatar
If you go to the track you should have oil temp and water temp. The stock gauge for water will tell you something is wrong too late and there isn't one for oil.
Quick Reply: Gauges For N/A setup
