CEL light after Berk test pipe install
i have put about 100 miles on the car since i installed the test pipe and no CEL. today on my lunch break, the CEL light comes on. what is the plan of action from here?
How is it not the test pipe on an AP1... what difference does it make? I'm seriously asking.
I had a test pipe on my '05 for a little while and then it threw a code after about 100-150 miles on it. (may have been more)
It was P420 I think. Which is the O2 sensor. I just took it out, cleaned it and put it back, and reset the ECU. Haven't seen the code again. I got the 70mm with the CEL fix too. Go figure.
cuz the ap1 part has a longer nipple welded onto the entrace hole for the o2 sensor allowing the o2 not to be directlly in the path of exhaust gasses. The ap2 rewuires the same nipple or bung on it.
got the check engine light checked at autozone this morning. here is the read out:
P0420
Catalyst system efficiency below threshold bank 1
Probable cause
- a/f ratio concern
- air leak near H02S (heated oxygen sensor) bank 1
- ignition system concern
- faulty catalytic converter
P0420
Probable cause
- a/f ratio concern
Would moving the O2 sensor further out of the flow via a spark plug defouler help?
My Berk 70mm on AP2 throws a CEL (P0420) reliably after 6-7 engine starts, regardless of miles driven.
