Brian Crower Stage 3 NA Cams
So I have this on order, expecting it within a few more weeks. I will be posting pictures of the build with titanium retainers and duel valve springs.
One thing I noticed is that BC mentions that aftermarket pistons are mandatory. What I want to know is why; aren't our oem pistons good enough? If anyone could bring light to this, please do! As I feel there is no need.
If the case is that I must, then the build will have to wait until I save up for a stroker kit later on
Based on testing done by wadzi, the stage3 make less power than the stage2 even with high compression pistons (he was runing over 13:1) unless you have Serious modification.
The stage3 are probably more suited for people who are putting tsx cranks in their f2#c's, have a 9k+ revlimit, and have itbs.
Sent from my T-Mobile G2 using Tapatalk
thanks for the replies!!
So what I'm getting is, I pretty much should get a stroker kit to get the full potential of these cams? even if my mods are: 4.77 gears, pwjdm intake, 70mm test pipe, 70mm exhaust and t1r headers + aem ems.
Wadzii, why do you believe they are "just wrong?" lol
Banned
they just reused their k-series profiles which obviously doesnt work very well.
I dont know if its the lobe centers or profiles that dont work but something doesnt work about these profiles.
wow, i didn't know that at all.
I just checked out your comparison between the two cams and I'm shocked at the results, it was a great write up too lol
I'll be calling BC and switching my order to stage 2. Thanks for the help!!!
