Blow by and venting discussion.
#161
I'm not sure if Honda sells just the baffle.
I'll keep thinking of other ways to help solve your problem.
How big of a hole did you drill?
You may have drilled too big of a hole, I'll do a DIY with better pics and specs, I'll also eliminate that hole under the PCV all together on AP1's and possibly AP-2's
#164
if you are getting fumes in the car, then your catch can is not properly of effectively collecting the oil. how is you set up?
anyways, i have a question. i an getting ton of crap. my catch can is either way to efficient or more car is just dumping so much crap out. i drive less than 200 miles and my catch can is full or over flowing. it is about half a cup size every 200 miles. 200 miles daily driving. no, hard driving. just city and highway. what is going on. but apparently my car also picked up about 5 whp adding a catch can. i guess less of that honey mustard is going into the intake manifold.
#165
Originally Posted by dan_uk' timestamp='1328027570' post='21369453
anyone with a vented catchcan getting fumes in the cockpit?
a day in my car at the track and I feel like crap
I was gonna run the filter out to the wheel well to see of that cures it
I have both the front breather and the PCV line connected to the can and a little filter to vent at the top of the can.
Then capped off the holes on the intake manifold.
#166
You might want to look at the seal that seals off the hood and firewall area. If you have a vented hood then switch your cabin fan from fresh air to recirc because there's nothing you can do other than not venting that stuff to the atmosphere.
#167
why not just run the breather filter on a hose into the fender wheel/under the floor pan?
#168
#170
No, the system won't work as it was designed to. The best option is to have 2 OCCs, one for 1/2 inch hoses and one for 3/8 hoses. If you research how that system came to be on production cars you'll know how to set it up for your needs
