Advice on custom intake
So I'm thinking about making a custom cold air intake. Is there any benefit to using piping bigger than 3 inch? Below is a picture of my setup right now. This is just a little project to keep me busy while I'm saving up for a bigger turbo and better manifold. Was previously Greddy turbo so that is why I have the intake pipe with a BOV. Second question is with my setup am I losing power over the stock intake? Piping is 2.75 inch and the plastic duct is 3 inch.
Yes, the BOV is LOL on my NA engine, thats part of the reason why i'm making a intake. I know piping is usually 3 inch but I'm wondering if using 3.5 inch or even 4 inch would make any kind of difference? The AEM v2 uses larger piping taper into a smaller piping so would it be beneficial to run larger piping all the way to the throttle body? Tuning is not a problem as I'm using AEM series 2.
Supposedly the optimal intake diameter is determined by the throttle body diameter, which is determined by plenum volume. But that's probably a little more in depth than you wanted to go.
Originally Posted by s2knoob89' timestamp='1315427095' post='20951695
I will be using aluminum piping.
Now I have another question on the intake design. I read in a another thread that our engines like a longer intake pipe. The way I have the intake routed in the pics, is it long enough? Trying to do this right the first time so I would appreciate anybodys opinion who have experience with this kind of stuff. I'm pretty much 100% certain I'm going to use 3.5 inch pipe unless somebody can give me reason not to. Thanks!
