S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
From 375whp Turbo S2k.. Boom...to: built LS6 with a bunch of goodies !
Old 12-09-2013, 01:24 PM
  #401
s2kt3's Avatar
so i finally got some more parts in and am slowly starting to get ready to kick it into high gear !!
pics !!
first I cut the subframe up to make taking my long tube headers in and out that much easier... this was my choice I did not have to cut away this much but I did, cut and boxed back in for structural support !
Old 12-09-2013, 01:27 PM
  #402
s2kt3's Avatar
cut a piece of sheet metal to box it in, cut a template with cardboard and traced it onto the metal
going to paint it with rust paint once I finish filling all the holes
and the final product, (other side looks the same) painted, filled, and so much room now !!!!!!!
Old 12-09-2013, 01:35 PM
  #403
s2kt3's Avatar
So the next thing is to install my short shifter, this thing is awesome !!!!
cleaned surface so the rtv will adhere properly and wont leak
and installed
more to come soooon. got some parts at my box in buffalo, going this weekend!
Old 12-09-2013, 02:35 PM
  #404
xyster's Avatar
Lookin good just as expected.
Old 12-09-2013, 04:53 PM
  #405
herecomesboost's Avatar
Nice job Lee. How long have you been welding?
Old 12-09-2013, 08:02 PM
  #406
s2kt3's Avatar
Thanks guys !!
Kyle, welding...... Many years but 95% on exhaust where the steel wall thickness is much greater. This was my first time welding thin thin sheet metal to a thick object, it was hard to not blow through the thin while heating up the thick enough to get penetration. I found it easiest to just do tacks 1/2" apart all the way along then fill it in after, that's why it looks so uneven, but it didn't matter because then I just ground it down fairly even anyways.
Old 12-10-2013, 04:03 PM
  #407
Carl Bourbon's Avatar
So this is where you are nowadays!
Still doing good work I see, about to test fit tomorrow, any last minute tips/tricks?
Old 12-10-2013, 07:25 PM
  #408
s2kt3's Avatar
It will need to come in and out a couple of times, watch the reverse switch on the trans I broke mine off first time haha. Hammer the tunnel back it will need quite a massage.
Old 12-10-2013, 07:30 PM
  #409
s2kt3's Avatar
Moooaaarrrr parts !!!!
Headers !!!
So that's it I have all my parts to put the motor back in !!!! Going away this weekend so won't have much time til next week.
Old 12-19-2013, 04:58 PM
  #410
s2kt3's Avatar
got a little more done tonight, in need of some studs, so I called it quits.
more to come.
Quick Reply: From 375whp Turbo S2k.. Boom...to: built LS6 with a bunch of goodies !
