From 375whp Turbo S2k.. Boom...to: built LS6 with a bunch of goodies !
#323
Total cost can vary so much up or down depending on what you do at the time of the swap. Examples are shaving and tucking the bay. Upgrading the radiator ( not a must) upgrade the clutch and other engine parts while it is out. Fuel system and the kind of lines and fittings you do. And the biggest would be the cost of which you get the LS motor for. Also if you do the labor yourself or not.
#324
I upgraded the rad, fans, clutch, throwout bearing (gm performance), brakes (4piston calipers), lines, short shifter, oil pressure gauge, wideband, bought hp tuners out right, 3" tig welded exhaust, ls6 intake manifold, ported throttle body
Swap kit, driveshaft, motor and trans, wiring and ecu, massive parts list as part of the swap
All in was around $12000..... Installed
Cost of my garage/ facility to do the swap $15000
Labour $12000.00 (I am a licensed Master Tech)
Good luck !
Lee
Good luck !
Lee
#325
Woot I'm glad u liked the drive.... Coming into that s corner going 70mph hahaha on stock suspension stuck and gone !!!!! Mmmm torque !!!!!
#328
It's a great investment and eventhough the community is small as of now importmuscle offers some of the greatest customer support if not the greatest customer support i have seen
