Yellow DRL? and HID at same time?
Hey,
i tried searching but couldnt find an answer.
Is it possible to get the day time running lights on with the HID's?
i want to put Yellow bulbs in it. also what bulb size?
has anyone done this? if so any pictures and DIY's?
Thanks
Thanks
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
are you talking about putting a yellow bulb inside your projector and running it as a drl? the projector is a D2S bulb size. you have to buy a 3000k temp d2s bulb for that.
if you just wanna run a yellow halogen bulb in your high beam area and run that as a drl that would be more appropriate so you can retain your regular hid.
Originally Posted by wOlLeyLaBeL,Aug 13 2008, 09:50 AM
i think hes talking about just changing the DRL light bulb to yellow...and having that DRL stay on while his projectors are on....
Originally Posted by HankookS2K,Aug 13 2008, 12:55 PM
well if his car is a 2003, he does not have drl's. the only way to get a drl into the ap1's is to purchase a relay made to power the high beam at half power. if thats all he wants to do a cheap yellow halogen bulb will work in the high beams. and you can wire that up so when you turn on your low beams your drls will still be lit.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Im kinda in the same boat. I wanted to get yellow bulbs for my high beams but only want them to come on when i turn on my low beams. Is that possible? And how much work would it be to accoplish?
