Widest tires on stock rims
If you go with the 265/40-17 out back you have to run taller tires up front to match the rear. The 235/45-17 fit my '06 and don't rub at all and they are the same height as the 265/40-17 tires(25.3").
ROD
ROD
My fronts(235/45-17) don't but I think the rear can rub with the wrong alignment, but maybe someone with more info will chime in here. The post that showed the 265/40-17 out back had his car lowered 2" I think, so if your on stock springs that should give you more room.
ROD
ROD
