whats broken in the rear end?
ok, i take the car out for a little boost fun.I do 2 runs and drive back 5 miles to my house.as i make a sharp turn right at my street i hear a clunking noise coming from the right rear tire,almost sounds like a flat. i check it out and no flat tire. i drive a few feet front and back and the clunking is louder. i call the last owner and he says to check to see if the tire lugs on loose.the rear wheels both have only 1/8th clearance from the brake calipers. they have those longer lugs on the wheels than stock. the wheel that that seems to be making noise has 0 clearance from the caliper,and the one that dosnt still has about a 1/8 inch. i took the wheel off and tightened it,no luck it still is rubbing. what do you think happened?did something break or loosten the wheel to now rub? it a a kaaz rear .
Kaaz 1.5 way rear diffs will pop when you make a turn off the accelerator. I had on in my turbo miata that was installed correctly and it would pop whenever I would be turning and not giving it any gas.
about those aftermarket diffs. are they worth it? what are the pros and cons? I hear they need to be rebuilt time to time, is this true? a friend of mine wants to swap his 1.5 LSD for my Stock rear. he doesn't like the chunking noise as well.
solitarycheese
08-08-2014 06:17 AM
