Transmission gear ratios
Old 09-12-2008, 09:41 PM
zbrewha863's Avatar
Default Transmission gear ratios
(Just so there's no confusion ... lower gear ratios are higher numerically, and vice versa)
Besides going to a machine shop and having a set made, is there any way to change up the gear ratios in the transmission?
I've heard of ... I think it was RSX owners who would swap in an ITR ratio set, b/c it had lower 1-5 gears and a higher 6th gear ... which is what I want on my S2000. That would allow faster acceleration (lower gear ratios) while giving increased gas mileage (better for sure in 6th gear -- who passes in 6th anyway?) on the highway and around town, since you could just cruise one gear higher.
Any solutions for the S?
Old 09-12-2008, 09:50 PM
qbmurderer13's Avatar
Look into an AP2 tranny. Much better than an AP1 tranny. 1-4 are shorter and 5-6 are a bit longer for highway cruising. The AP2 tranny also shifts alot more smoother and has carbon synchros.
Old 09-12-2008, 09:54 PM
zbrewha863's Avatar
Cool, good info, thanks
Old 09-13-2008, 02:05 AM
fltsfshr's Avatar
Received 1,058 Likes on 540 Posts
actually 1 to 4 are the same ratios in the box 5th and 6th are different.
If you order a new set of ap1 synchros you get the cf ones from honda for both trannys.
The difference in the tranny's is the reduction gear is shorter in an ap2. That gear affects all of the others.
Lots of threads on this. Do a search. cheapest way is to replace with an ap2.
fltsfshr
Old 09-13-2008, 02:39 AM
zbrewha863's Avatar
Yeah, I think I either failed to adequately explain my goal or it was misinterpreted.
I do not want a shorter reduction gear or a longer 5th gear. I want shorter individual 1-5 gears with a longer 6th gear. Basically a setup that can be used effectively on any track (through 5th gear) but still has a longer 6th gear (which I wouldn't get into on a track) for gas mileage.
Old 09-13-2008, 06:24 AM
Revenge's Avatar
I think the AP2 tranny is still a better option based on what you want.
Old 09-13-2008, 06:48 AM
fltsfshr's Avatar
AP1
6-speed, close-ratio
Primary Gear Reduction - 1.160
1st gear - 3.133 --- Est speed @ 9000rpm ~ 45mph
2nd gear - 2.045 --- Est speed @ 9000rpm ~ 60mph
3rd gear - 1.481 --- Est speed @ 9000rpm ~ 90mph
4th gear - 1.161 --- Est speed @ 9000rpm ~ 115mph
5th gear - 0.970 --- Est speed @ 9000rpm ~ 135mph
6th gear - 0.810 --- Est speed @ 9000rpm ~ 160mph
Reverse - 2.800
Final Drive - 4.10 with Torque-Sensing Limited-Slip
AP2
6-Speed Transmissions Gear Ratios:
Primary Gear Reduction - 1.208
1st gear - 3.133
2nd gear - 2.045 --- Est speed @ 8000rpm ~ 52mph
3rd gear - 1.481
4th gear - 1.161
5th gear - 0.942
6th gear - 0.763
Reverse - 2.800
Final Drive Ratio - 4.100
5TH comes out shorter with the reduction but 6th comes out longer. I don't know if the gears are interchangable
Old 09-13-2008, 07:43 AM
RedY2KS2k's Avatar
With enough money, all things are possible.
Old 09-13-2008, 12:34 PM
pyro40t's Avatar
So what your saying is the ap2 tranny doesnt have a limited slip in it at all?
Old 09-13-2008, 01:23 PM
zbrewha863's Avatar
^^^Seriously?
RWD transmissions don't have differentials in them. No RWD transmission has a limited slip.
Quick Reply: Transmission gear ratios
