Transmission fluid change
I was reading earlier today about a procedure and I was wondering if it is a good, bad, or doesn't matter. Basically, when filling the the transmission with the transmission fluid you drop down the passenger side of the car a little bit so you can "squeeze" in a little bit of extra transmission fluid. I am changing my transmission fluid tomorrow and I was thinking about trying this if it is not harmful to the car. Any information shared would be much appreciated. Thanks all.
-Ian
-Ian
You drop the passenger side to to get a little extra fluid in and then you raise the passenger side back up to level. When you do that, any excess will run out. Wipe the area clean and put your fill bolt back.
yep, over filling fluids does no good. they put the fill plug where it is because its measured out to where your fluid needs to be. its supposed to be an idiot proof design so that someone cant over fill, but apparently it doesnt always work.
ok first of all why would you drop the transmission for a fluid change? you take the fill bolt off, then the drain bolt. Wait until it drains. Plug the drain hole and then refill with new fluid. get a pump from auto zone or pep boys to pump the fluid. then once it starts leaking leave it for 5 mins so it can even out. then plug the fill hole. and ur done. took me 15 minutes on saturday to do it.
i dont even know where you are getting your info from but thats wrong. hopefully the didnt tell you to fill the engine with oil until it spills from the valve cover.
ha ha, thanks for the replies guys. I didnt mean drop the transmission. I think im just going to do it regular and be better safe than sorry. hearing people call me stupid helps when a dumb idea makes its way into the brain. Have a good one.
-Ian
-Ian
Level the car with a level using the front brace under the hood and the frame on the side underneath. Then fill until it starts to run out. Let it get to a consistent very light flow then close up. Done.
