Throttle body spacer(p2r)
Old 09-14-2010, 04:54 AM
  #21
AngryTurtle's Avatar
Originally Posted by KC2001AP1,Sep 14 2010, 03:15 AM
I DIDNT KNOW THAT P2R SOLD A SPACER,BUT I DO HAVE THE P2R GASKET.TO HELP WITH HEAT ALONG WITH THE INTAKEMANIFOILD GASKET.THERE WAS NO POWER DIFFERNCE,BUT THE MANIFOLD IS COOLER TO THE TOUCH.
I DONT KNOW HOW TO USE A KEYBOARD BUT I DO KNOW THAT WHEN I HIT THIS ONE BUTTON IT MADE MY LETTER BIGGER.
Old 09-14-2010, 05:45 AM
  #22
Former Sponsor
Gernby's Avatar
I don't see how adding a measly 4 cubic inches of volume to the intake manifold would make a measurable difference in power. I also don't see how insulating the TB would make a difference IF you've already insulated the IM with a Hondata IMG. My TB is always cool, unless it's been sitting for a while.
I also suspect that adding the 3/4" spacer might cause problems for the intake, since you will be moving the mating surface 3/4" closer to the radiator. Depending on which intake you have, you may not be able to do that. It might even cause problems with STB clearance (I'm not a fan of STB's).
Old 09-14-2010, 07:37 AM
  #23
ap1_tot's Avatar
Old 09-14-2010, 07:56 AM
  #24
MikeyCB's Avatar
^ Sooooo....any comments aside from the picture showing that you have it?
Old 09-14-2010, 08:38 AM
  #25
hypforlife32's Avatar
gernby, i have a aem v2. clearence isnt a problem. ^^^ the guy about has the same style intake. the 2 gaskets are made out of the same material as the hondata IMG.
its equal to getting a little larger intake manifold. mostly the tb spacer makes more tq beacause of the volume readily avaible. k series guys with a tune are getting good whp out of them. even tuned without one and then some airfuel trimming/adding and are getting another 4-5whp and 6-8lb tq.
Old 09-14-2010, 05:31 PM
  #26
H22toF20's Avatar
The P2R TB gasket works due to the fact that you have coolant running through the TB for the IACV; pre-DBW. As far as the spacer, it may or may not work. You are adding volume to the plenum, which should yield gains in the top-end; in theory. I just don't see how a little bit more volume right behind the TB, would do much of anything.
Old 09-15-2010, 05:34 AM
  #27
donaldmejr's Avatar
Guys remember P2R also makes a TB Spacer/Adapter that allows a 2009-2010 Acura TL AWD 80mm DBW TB to bolt up.
Yes this is for an accord but they make one for the DBW S2000
http://j-series.org/forums/showthread.php?p=29
Old 09-15-2010, 05:47 AM
  #28
Former Sponsor
Gernby's Avatar
The Hondata IMG will block coolant flow through the TB, but I don't see how the P2R spacer would block coolant. There are no coolant passages through the TB gasket.
Old 09-15-2010, 06:07 AM
  #29
ans2k's Avatar
too bad that doesnt bolt up to the s2k or at least it didnt look like it would
theS2K
09-02-2013 02:57 PM
J_STATUS
06-09-2008 04:33 PM
S2Race
02-19-2008 02:11 PM
vvtli78k
01-02-2007 05:21 PM
Joe04sk
05-16-2005 05:59 PM
Quick Reply: Throttle body spacer(p2r)
