throttle body coolant bypass....and CO2?
Old 10-04-2011, 04:50 PM
  #31
Andrie's Avatar
Originally Posted by Boofster
This is also great if you have the coolant-block Hondata IM gasket.
Where do you get this gasket? I can't find it on Hondata site. The one on the website have holes for the coolant to go through.
Andrie is offline
Old 10-04-2011, 05:49 PM
  #32
K1LL3R 1NS1D3's Avatar
I picked it up on sale from Blueridge. They are right down the street from me. Mine had a mark where the hole should be and on the instructions said you could drill that out if you wanted the coolant to pass through. Basically the img blocks off coolant from the throttle body and the iac if you dont drill the hole out so bypassing the lines isnt required anymore unless your just cleaning up clutter in the bay.
K1LL3R 1NS1D3 is offline
Old 03-20-2013, 10:28 AM
  #33
SlowTeg's Avatar
Does the hondata IM gasket block off flow through the manifold or just insulate? Just wondering if you can cap off the large outlet from the head that goes through the intake manifold.
I had a hondata IM gasket on my old b series motor w/ the blocked off outlet to the IM, and it worked great. I'll take a peak at my helms manual to look at the coolant hoses, but I'd guess it'd be very similar to a B-series, and blocking off the intake manifold port shouldn't hurt anything.
SlowTeg is offline
S2SEXY
05-01-2015 05:09 AM
forplay
02-21-2007 06:14 AM
Startrek
12-25-2006 09:27 AM
Quick Reply: throttle body coolant bypass....and CO2?
