Is there a DIY for cruise control button relocation?
I could've sworn there was a thread here somewhere that showed someone with an aftermarket steering wheel that added a momentary switch somewhere in the console that served the purpose of the "set" button for cruise control but I just can't find it again (I tried all possible search term combination). I don't care about "cancel" or whatever the other button is since stepping on the brakes should disengage cruise for me but I think I actually would like to be able to set cruise control again. I don't use it often but since I'm driving up to Watkins Glen in a few weeks which is a 5 hour drive for me, it would be nice to be able to give my leg a break. Anyone know where that thread is or if there is some other DIY for getting this done? Obviously I don't have a stock steering wheel on my car as I wouldn't be asking this question otherwise.
Thanks,
Steve
Thanks,
Steve
Originally Posted by Gigdy' timestamp='1315918989' post='20968104
do you still have the clock spring? If so you can just plug the OEM buttons back in and attach them to you column.
Ok so I found this post by Modifry:
https://www.s2ki.com/s2000/topic/486...t__p__10468579
and then this PDF on the shift beeper install:
http://www.modifry.com/products/rlb/...nual%202.2.pdf
Since I don't have a soft top, say I wanted to use my roof switch as my cruise "set" button, does that mean I just have to wire the red/black wire for the roof switch to the light green/black wire on the cruise control module?
